This is Argonne National Laboratory’s R&D version of GREET.
For GREET versions used for determining tax credits, please click here.
A brief introduction to R&D GREET can be found here.
R&D GREET Battery Module
Click to save and extract the .zip file R&D GREET Battery Module File.zip to your hard drive. It contains the interactive excel file “GREET Battery Module”, R&D GREET vehicle cycle database (GREET2_2024) that works in the background, and the instruction manual.
January 10, 2025
R&D GREET Battery Module 2024
The GREET team at the Systems Assessment Center of Argonne National Laboratory is pleased to announce the release of the updated R&D GREET Battery Module.
The Systems Assessment Center at Argonne National Laboratory has developed an interactive, standalone battery module (R&D GREET Battery Module) to have a consistent battery life-cycle analysis platform with the most up-to-date datasets. It is intended to facilitate a user-friendly way of investigating the inventory and the environmental impacts/emissions of select battery chemistries available in R&D GREET. For easy access, this module uses Microsoft Excel with Visual Basic for Applications (VBA) to enable an interactive user interface.
In this release, we include background datasets for batteries with the most up-to-date R&D GREET 2024 excel module. The R&D GREET Battery Module interacts with the R&D GREET vehicle cycle model (GREET2) by directly reading upstream life cycle energy uses and emissions for key inputs to various stages in various battery production pathways. This version allows the user to change critical supply chain information for battery materials like lithium carbonate and hydroxide. Users can also modify the life cycle energy and emissions of the key manufacturing steps like cathode production and battery assembly. Additionally, users can modify the upstream emissions associated with key auxiliary materials like aluminum and graphite and investigate the resulting change in emissions from a unit kWh battery produced in the U.S.
The connection to the R&D GREET2 model is automatic and it works in the background to provide the results to the interactive R&D GREET Battery Module excel file.
For detailed instructions on how to use the module, please refer to the following link: (400 KB pdf)
Technical contact: [email protected]
The R&D GREET Battery Module is developed with Microsoft Office 365. For best performance, we highly recommend using Microsoft Office 365 to run the module.
To download and open the R&D GREET Battery Module:
  • Click to save R&D GREET Battery Module File.zip to your hard drive
  • When the download is completed, extract the zip file
  • Double click "GREET Battery Module 2024.xlsm," and choose to "Enable Macros," if prompted.
  • You may need to unblock both spreadsheets by going to the properties and making these as trusted documents.
Prior Revisions
No prior versions
- R&D GREET Battery Module: Beta - Released: December 21, 2023
